[Mercado] Tópico-chevrolet ( Spark, Aveo, Cruze, Trax, Orlando, Captiva, Volt, Camaro )
citação:Originalmente colocada por SevenTrixx
Chevrolet prepara novo visual para o Kalos
Futuro Aveo(?) 5 e 3 portas
</u>
Earlier this year, we saw the much-appreciated update of Chevrolet’s subcompact Aveo sedan. Today, we’re proud to bring you a glimpse of the hatchback’s makeover, thanks in part to Photographer Chris Doane.
Slated for a 2007CY introduction as a 2007MY vehicle (hence our calling it a 2007.5), the next Aveo five-door will carryover the drivetrain with similar mileage improvements to the sedan and likely similar interior upgrades as well. The interior in this caught car is covered. What's hiding? We can't say for sure.
However, unlike the original Aveo pair, this hatchback will get styling enhancements all its own. Looking at the rear tells us that circles are the way of tomorrow at Chevrolet. A large, round housing holds the taillamp with the reverse lamp dominating the inset. That whole unit cuts into the bottom of an HHR-sized brakelamp above. Clearly, much for flash is intended for this car.
A glace up front shows a much larger, more aggressive Chevrolet bisected fascia similar to what we’ve seen in recent Malibu spy photographs. Foglamps are housed on either side of the big lower opening. Larger, bolder headlamps flank the equally large upper grille opening in what seems to be a ‘blugier’ hood. However, the most interesting feature is the two-slot side vent located above the repeater lamp on either side of the car. No, this is not a trick of your vision, as it is clearly seen in the enlargement. The placement abutting the front doorlines shows this is also not some engineer’s idea of fun but apparently a real production piece.
Could this be a performance trim, or a portent of one to come? We cannot say for sure, but the existence of what is still a rather upmarket and trendy styling trait shows GM’s stylists won’t be left behind. Pricing, by the way, will start at just under $10,000, again making Aveo a true value leader.
As for what comes after this, look towards 2010CY/11MY for the next-generation Aveo. Spawned off the future proposed GMDAT Gamma platform, the new Aveo is likely to be powered by 1.5l 3cyl Diesel engine, likely just overseas. Not much is known about this vehicle so far, but with the strong introduction of the first Aveo and sales skyrocketing along with gas prices, expect GM to take this market very, very seriously.
citação:Originalmente colocada por JeTBoy
Muito bonita a carrinha Nubira.
Sou um apreciador dos modelos Chevrolet, mesmo daqueles que derivaram da Daewoo, gosto particularmente do Lacetti e do "jipe" Captiva
Infelizmente continua a haver um preconceito infundado em relação a esta marca[8], talvez por derivar da Daewoo, mas com o tempo acredito que se dissipe.
Já agora qual o modelo de segmento superior, o Evanda ou o Epica? O Evanda não era o anterior Leganza?
È o Epica
pois este veio substituir o Evanda.
Exacto.
Cá em casa há um Evanda [:I]
citação:Originalmente colocada por Sphynx
Existe aqui lugar pra comunidade Daewoo?É que visto a marca ter sido absorvida, somos marginalizados, desprezados, não nos conseguimos integrar. lololol
Agora sem ser no gozo, acho que ja estava na altura da chevrolet mostrar alguns modelos da Chevy USA na europa, principalmente para o segmento de topo.
oh moço somos poucos mas bons...
venham lá eles com os 1.3 cdti's,e os 1.2 16v...
nao temos medo de ninguem =) :D
comprava o Lacetti [:I]
o meu Lanos já tá a começar a ficar "gasto",é de '99 só tem 90.000kmh mas já é muito ano...
Chevrolet Volt Concept Sedan Specifications
Overview
Model: Chevrolet Volt Concept
Body style / driveline: 4-passenger sedan, unitized frame, electric propulsion, front wheel drive
Construction: body-frame-integral structure with composite exterior panels and roof
EPA vehicle class compact car (four doors with rear liftgate)
Drive system
Description: electrically driven system with onboard range extender, plug-in recharge capability
Battery system:
Type: lithium-ion
Energy: 16 kWh (minimum)
Peak power: 130 to 140 kW
Voltage: 320 to 350
100% recharge time:
110-volt outlet: 6 to 6.5 hours
Electric traction system:
Max. electrical power: 130 to 140 kW
Max. mechanical power: 120 kW
Continuous electrical power: 45 kW
Continuous mechanical power: 40 kW
Generator:
Power: 53 kW peak power
Drive: direct
Range extender:
Type: 3-cylinder, turbocharged engine
Fuel: gas or E85
Nominal speed: 1500 to 1800 rpm
Max speed: 3200 rpm
Fuel tank (gal / L): 12 / 54.5
Charger:
Type: plug-in
Voltage / amp: 110 / 15
Horsepower (hp / kW): 160 / 120
Torque (lb-ft / Nm): 236 / 320
Electric mode range: 64 km (40 miles) – full electric vehicle (EV) range
Estimated fuel economy @ constant state of charge: 4.7 l/100 km (50 mpg) during charge sustaining operation
Daily usage equivalent mpg:
@ 64 km (40 miles) or less: not applicable – no fuel used
@ 96 km (60 miles): 150 mpg
@ 128 km (80 miles): 100 mpg
0 to 96 km/h (60 mph): 8 to 8.5 seconds
O futuro dos hibridos.
Em vez de um motor eléctrico assistir o motor de combustão, temos o motor de combustão a assistir 1 motor electrico.
O motor de combustão não se encontra ligado de alguma forma às rodas. Apenas serve para fornecer energia ao motor eléctrico.
Técnica interessante já vista há uns meses por uma empresa que transformou um mini. Tinha os motores electricos inseridos directamente nas rodas, como a mitsubishi com o seu sistema MIEV, dando ao mini 640cv de potência.
10 Janeiro de 2007
Recorde de vendas da GM - mais de 2 milhões de veículos vendidos na Europa em 2006
• Mais 18.743 unidades da GME vendidas no exercício em curso face ao anterior
• Vendas da GM na Rússia crescem 73% em 2006
• Modelos Corsa, Meriva, Astra, Zafira e Vivaro da Opel/Vauxhall com bom desempenho
• Saab atinge melhor recorde de sempre de matrículas na Europa e no resto do mundo
• Chevrolet estabelece novo recorde, ultrapassando as 340.000 matrículas</u>• Vendas da Cadillac no exercício em curso crescem 22%
Em 2006, pela primeira vez na sua história, a General Motors (GM) vendeu mais de dois milhões de automóveis de passageiros e veículos comerciais ligeiros na Europa. O recorde de vendas anual equivale a 2.002.704* veículos, número que representa um acréscimo de 18.743 unidades (+0,94%) face ao exercício anterior, apesar das reduções substanciais das vendas a rent-a-car. A quota da GM no mercado europeu (Europa Ocidental, Central e Oriental) foi de 9,2%. As marcas da GM superaram significativamente o crescimento da indústria na Suécia, Dinamarca, Finlândia, Irlanda, Suíça e Espanha, bem como em sete mercados da Europa Central e Oriental e no mercado em rápida expansão da Rússia, onde a GM melhorou as suas vendas em 73% (132.600 unidades, + 56.022 unidades) face a 2005.
“2006 foi um ano de viragem para nós. Pela primeira vez, vendemos mais de dois milhões de veículos e, ao mesmo tempo, melhorámos substancialmente a receita média por veículo e lançámos as fundações para um crescimento sustentado. Conseguimo-lo com um saldo de investimento saudável em grandes novos produtos, vendendo veículos melhor equipados e reduzindo as vendas de frotas de baixa margem”, declarou Jonathan Browning, Vice-Presidente para a área de Vendas, Marketing e Pós-Venda da GM Europa.
Chevrolet obtém recorde de vendas acima das 340.000 unidades</u>A variação anual do crescimento da Chevrolet foi de 15%, cifra que conferiu à maior marca global da GM um total de vendas de 341.612 unidades e uma quota de mercado de 1,6% (contra 1,4% em 2005) na Europa. Estes números incluem cerca de 48.800 veículos construídos pela GM-AVTOVAZ e veículos produzidos nos EUA, tendo ainda 292.800 veículos sido importados da Coreia (mais 21,5% do que em 2005). Em 2006, a principal área de crescimento foi, de novo, a Europa Central e Oriental, com vendas superiores a 188.000 unidades e um crescimento total de 33,5%. Na Rússia, a Chevrolet vendeu mais de 111.400 veículos, dos quais perto de 43.300 unidades provenientes da GM-AVTOVAZ e produzidas pela GM nos EUA, contra 67.000 unidades em 2005. A Chevrolet registou bons resultados de vendas na Alemanha (23.486 unidades; + 13%), Itália (36.750 unidades; + 5,3%), Espanha (28.410 unidades; + 4,9%) e ainda em mercados de menor dimensão, como a Suíça (mais de 3155 unidades; + 12,2%), Noruega (1121 unidades; + 9%) e Irlanda (2139 unidades; + 8,2%).
A General Motors Corp. (designação na Bolsa de Valores de Nova Iorque: GM), o maior fabricante de automóveis do mundo, é líder mundial de vendas da indústria desde há 75 anos. Fundada em 1908, a GM emprega hoje cerca de 318.000 pessoas em todo o mundo. Tem operações de fabricação em 33 países e vende os seus veículos em 200 países. Em 2005, a GM vendeu globalmente 9,17 milhões de veículos de passageiros e industriais, número que correspondeu a uma subida de 2% e ao segundo melhor total da história da companhia. Na Europa, a GM vende as gamas das suas marcas Opel, Vauxhall, Saab, Chevrolet, Cadillac, Corvette e Hummer em mais de 30 países. Opera 11 unidades de produção e montagem em oito países e emprega cerca de 62.500 pessoas. A GM opera também uma das maiores sociedades de financiamento do mundo, a GMAC Financial Services, que presta serviços de financiamento e seguros nas áreas automóvel, da habitação e comercial. Para obter mais informações sobre a GM, visite os endereços http://media.gmeurope.com e http://www.gmeurope.com.
Chevrolet Epica 2.0 VCdi 150cv ( diesel)
já esta disponivel o Epica a Diesel
Epica - Motor turbodiesel 2.0 VCDi com 150 cv e binário de 320 Nm
• Motor turbodiesel 2.0 VCDi de última geração, com 150 cv e binário de 320 Nm
• Estilo dinâmico, elevado conforto e condução suave
• Muito espaço para os passageiros e excelente insonorização
• Vasto equipamento de série e conjunto completo de sistemas de segurança
A Chevrolet acaba de lançar no mercado português uma motorização turbodiesel na berlina Epica, reforçando significativamente os argumentos deste veículo que se distingue pelo seu estilo adaptado ao gosto europeu, espaço, conforto e relação preço/equipamento imbatível. Disponível também no Chevrolet Captiva, este novo motor é um 2.0 litros com injecção directa common-rail, cabeça de 16 válvulas e turbo de geometria variável, que debita 150 cv e gera um binário máximo de 320 Nm às 2000 rpm, estando equipado de série com um filtro de partículas livre de manutenção.
O Epica tem 4,81 m de comprimento e uma distância entre eixos de 2700 mm. Está no topo da sua classe no que respeita à habitabilidade, oferecendo muito espaço não só para passageiros como para bagagem (480 litros, de acordo com a norma VDA).
O preço do Chevrolet Epica 2.0 VCDi LT em Portugal é de €32.950 (€33.875 com caixa automática). Entre os principais sistemas e equipamentos de série, destacam-se o ABS com EBD e controlo electrónico de tracção, airbags frontais, laterais e de cortina, computador de bordo, programador de velocidade, bancos forrados a couro, rádio-leitor de CD’s/MP3 com carregador para 6 CDs e sensores de chuva e de estacionamento. (lista de equipamento completa no final deste documento)
Epica - Super equipamento de serie
Equipamento de série
Exterior
- Pára-choques e puxadores das portas na cor da carroçaria
- Faróis de nevoeiro dianteiros- Jantes de liga leve 7.0J x 17''
- Retrovisores laterais ajustáveis e rebatíveis electricamente
- Retrovisores laterais com indicadores de mudança de direcção integrados
Interior
- Abertura remota do depósito de combustível
- Abertura remota do porta-bagagens
- Arrumação para óculos de sol (condutor)
- Bolsas de arrumação nos bancos dianteiros
- Espelhos laterais aquecidos
- Luz interior de cortesia
- Pálas do condutor/passageiro com extensão
- Porta-copos (dianteiro e traseiro)
- Vários locais de arrumação
Conforto
- Comandos de rádio e programador de velocidade no volante
- Banco do condutor ajustável electricamente (8 vias)
- Bancos aquecidos, condutor e passageiro
- Bancos forrados a couro
- Bancos dianteiros com regulação do apoio lombar
- Volante ajustável em altura e profundidade
- Volante e punho da caixa de velocidades forrados a couro
Funcionalidade
- Programador de velocidade (até vel. máx. 180km/h)
- Computador de bordo
- Sensores de estacionamento (atrás)
- Direcção assistida progressiva
- Espelho retrovisor exterior com função de estacionamento
- Espelhos retrovisores exteriores com regulação e rebatimento eléctricos
- Sensor de chuva
- Vidros eléctricos (4)
Sistema de áudio
- Antena integrada no óculo traseiro
- Carregador 6 CD
- Altifalantes: 8
- Comandos de rádio no volante
- Rádio leitor de CD / MP3
- Tomada de corrente extra (12V)
Climatização
- Ar condicionado automático com controlo electrónico
Segurança
- Airbag duplo frontal (condutor e passageiro)
- Airbags de cortina
- Airbags laterais dianteiros
- Barras de protecção lateral
- Cintos de segurança de 3 pontos com pré-tensores (com limitadores de esforço, à frente)
- Cintos de segurança dianteiros reguláveis em altura
- ABS com distribuição electrónica de travagem (EBD)
- Avisador de abertura das portas
- Controlo electrónico de tracção electrónico (TCS)
- Pára-brisas com protecção térmica
- Regulação dos faróis
- Vidros coloridos com reflector de sol
- Encostos de cabeça dianteiros ajustáveis em altura e inclinação
- Sensor de desactivação automática do airbag de passageiro
- Sistema isofix de 3 pontos (cadeiras de criança)
Protecção anti-furto
- Fecho centralizado de portas com comando à distância
- Alarme (comando automático, com fecho centralizado)
- Imobilizador do motor
Vinha uma reportagem no Fugas (publico) de hoje sobre o epica!
[:cool:]
Se alguem quiser que poste aqui a opinião peçam [;)]
Cinco linhas de modelos Chevrolet, agora disponíveis com motores Diesel
Em 2007, a Chevrolet Europa terá para oferecer a opção de um motor Diesel em cinco modelos. Depois da convincente estreia do motor Diesel no SUV Captiva e da sua estreia para breve na berlina Epica, os compradores de um Chevrolet Nubira station wagon, de um Nubira sedan e do Lacetti passam também a poder optar por um motor Diesel. A Chevrolet apresenta a sua completa gama Diesel no 77º Salão Automóvel de Genebra. "Estamos agora a lançar a nossa ofensiva Diesel numa frente alargada", disse Wayne Brannon, Presidente da Chevrolet Europa. "No final da década, prevemos que um em cada três Chevrolets vendidos na Europa terá um motor Diesel".
Em Portugal, a Chevrolet vai oferecer duas versões do moderno motor Diesel 2.0 common-rail: o motor de 110 kW/150 cv irá propulsionar os modelos Captiva e Epica, ao passo que a versão de 89 kW/121 cv estará disponível nos restantes modelos. A página seguinte apresenta os dados técnicos de todos os modelos Diesel da Chevrolet.
O potente e económico motor Diesel de quatro cilindros integra a última geração do sistema common-rail da Bosch, cujos injectores bombeiam o combustível para as câmaras de combustível a uma pressão que pode ir até aos 1600 bar. Entre as restantes características deste motor com uma árvore de cames à cabeça estão a cabeça de cilindros em alumínio, a tecnologia de quatro válvulas e o amortecedor de vibrações.
Com a nova versão Diesel, o Lacetti e o Nubira terão novos argumentos. Até Dezembro de 2006, mais de 170,000 modelos Lacetti e Nubira foram vendidos na Europa desde o seu lançamento em 2003. E a popularidade dos Diesel entre os clientes Chevrolet é bem visível na taxa de veículos Diesel na família Captiva, que ascende a mais de 70%.
Chevrolet Camaro: captar um espírito intemporal ( talvez em 2010 em portugal !)
• Interpretação marcadamente moderna do clássico coupé desportivo
• Design espectacular e performance reactiva
• Nova versão de produção entrará na Europa em 2009
O Chevrolet Camaro Coupe Concept faz a sua estreia europeia no Salão Automóvel de Genebra de 2007. A Chevrolet Europa decidiu iniciar a importação da versão de produção deste veículo em 2009.
Combinando um design espectacular com uma performance empolgante, o Chevrolet Camaro Concept recupera o espírito de um dos mais populares coupés desportivos de sempre e redefine o Camaro com os olhos postos nas novas gerações de amantes da condução.
O Camaro Concept incorpora a performance e a paixão que colocaram os Camaro da primeira geração no grupo dos automóveis de colecção mais procurados, actualizando a fórmula com uma motorização eficiente no capítulo do consumo de combustível, um chassis sofisticado e um design com uma execução moderna. A finalidade é despertar a atenção dos jovens adeptos da condução para este coupé desportivo e, ao mesmo tempo, manter o seu poder apelativo junto dos admiradores actuais.
“Milhões de pessoas de todas as idades adoram o Camaro pelas melhores razões”, disse Ed Welburn, Vice-Presidente de Design Global da GM. “Os Camaro eram bonitos e ofereciam um nível de performance que rivalizava com os caros GT europeus. No entanto, eram suficientemente práticos para a condução do dia-a-dia e tinham um preço acessível para muitos dos clientes que procuravam um veículo novo”.
O longo capô, o painel traseiro curto e o porte largo do Camaro Concept não deixam dúvidas quanto ao seu estatuto de automóvel de alta performance. Estes aspectos visuais são complementados por um motor em alumínio de bloco pequeno V-8 de 400 cv, uma caixa manual de seis velocidades e um sofisticado chassis com uma suspensão independente nas quatro rodas.
Tal como os seus antecessores, o Camaro Concept seria suficientemente prático para o dia-a-dia. Integra sistemas de economia de combustível como a tecnologia de desactivação dos cilindros Active Fuel Management™ (Gestão Activa do Combustível). As suas dimensões adaptam-se confortavelmente às ruas da cidades e aos lugares de estacionamento suburbanos e o banco traseiro permite transportar ocasionalmente dois adultos.
Design elegante e musculado
Respeitando a herança de potência do Camaro, a equipa de design da GM escolheu um tema que é um tributo ao Camaro original, mas que, ao mesmo tempo, distingue imediatamente o concept como um veículo novo. O Camaro de 1969, por muitos considerado o detentor do melhor design da primeira geração, constituiu uma importante fonte de inspiração. Contudo, as equipas de design da GM de Warren, Michigan, EUA, trabalharam também em alternativas ao Camaro Concept, virando-se para o mais recente Corvette e para o avião caça YF-22 em busca de um design capaz de integrar o espírito que trouxe tanta fama ao Camaro de 1969, mas interpretado com um toque de modernidade e entusiasmo.
“As proporções globais, o capô comprido e as formas pujantes dos guarda-lamas dizem: este é um veículo de alta performance com motor à frente e tracção traseira, ” afirmou Tom Peters, director de design responsável por automóveis de alta performance com tracção às rodas traseiras. A proeminente grelha dianteira e a protuberância do capô deixam perceber a potência do motor V-8 inspirado no Corvette. Já as rodas e pneus de grandes dimensões, os travões de alta performance à vista e as formas salientes dos guarda-lamas dizem que o Camaro Concept tem uma maneabilidade e um sistema de travagem à altura da sua motorização.
O cockpit do Camaro surge entre as formas bem definidas dos guarda-lamas, um elemento de design inspirado nos caças e no novo Corvette. Além disso, tal como sucede em qualquer veículo de alta performance, o design simples e afirmativo insere-se na estética. “O Camaro Concept não é uma mera forma com estilo”, explicou Peters. “O seu design incorpora aquilo de que o veículo necessita para optimizar o seu nível de performance”.
O mesmo design afirmativo reflecte-se no interior do Camaro Concept. Os mostradores e o toque do acabamento cor-de-laranja remetem para os Camaros clássicos da primeira geração, mas, no geral, o design e a execução espelham a funcionalidade sem artifícios que os condutores esperam de um automóvel desportivo de alta performance da Chevrolet.
Performance a pensar na vida real
O Camaro Concept traz consigo a última geração do lendário motor V-8 de bloco pequeno da GM. O motor 6.0 LS2 possui um bloco e cabeças de cilindros em alumínio para reduzir o peso e a tecnologia Active Fuel Management™, que desactiva os quatro cilindros para poupar combustível com o motor em carga ligeira. Esta versão conceptual do motor LS2 tem uma potência de 400 cv.
A caixa manual de seis velocidades do Camaro Concept oferece uma ampla banda de relações para fortes acelerações, ultrapassagens seguras e um controlo eficiente da velocidade de cruzeiro em estrada.
Os automóveis desportivos são muito mais que velocidade de ponta em linha recta, pelo que o Camaro Concept está munido de um sofisticado chassis com tracção às rodas traseiras. A sua suspensão independente, à frente e na retaguarda, inclui molas de pressão progressiva e amortecedores de gás pressurizado. Os travões de disco ventilado existentes nas quatro rodas, com rotores de 14 polegadas, garantem paragens fiáveis em quaisquer condições. Por último, a performance e o visual do Camaro Concept são sublinhados pelas invulgares rodas em liga fundida de cinco raios (21 polegadas à frente e 22 polegadas atrás).
Tipo de veículo:
Coupé desportivo de duas portas com quatro lugares
Distância entre eixos (mm):
2806
Comprimento (mm):
4730
Largura (mm):
2022
Altura (mm):
1344
Via (mm):
Dianteira: 1620; traseira: 1607
Motor:
6.0-L V-8 LS-2, 400 cv / 298 kw, com tecnologia Active Fuel Management™ (Gestão Activa do Combustível)
Caixa de velocidades:
Manual de seis velocidades T56
Suspensão:
Independente nas quatro rodas: MacPherson à frente e multilink atrás, com molas espiraladas de pressão progressiva e amortecedores de gás pressurizado
Travões:
De disco nas quatro rodas, rotores de 14 polegadas com calços de aperto de quatro pistões
Rodas:
Alumínio fundido, 21 polegadas à frente e 22 polegadas atrás
Pneus:
Dianteiros: 275/30R21; traseiros: 305/30R22
