Desenvolvimento revolucionario nos motores gasolina?
NxSK
Banido
Something new to the internal combustion engine world is HCCI — Homogeneous Charge Compression Ignition, yet to be seen in any production vehicle by any manufacturer. A few car manufacturers have been experimenting with this, among them Honda who wants to introduce HCCI with it’s IMA Hybrid system.
What exactly is HCCI? Basically. Homogeneous Charge Compression Ignition ignites an air fuel mixture without any flame, plus a large area can be ignited simultaneously, much different from a conventional spark flame burn where the mixture burns first from the area around the initial spark and proceeds to the rest of the combustion chamber. This is somewhat similiar to a diesel engine’s self-ignition. Diesel self-ignition is called SCCI, or Stratified Charge Compression Ignition.
Engineers have predicted a potential 20 to 30% boost in engine efficiency over conventional gasoline combustion engines, and an improved thermal efficiency of about 40% to 50%. Honda calls it’s HCCI technology Activated Radical Combustion, and have been experimenting with two-stroke motorcycle engines. A 4-cylinder HCCI engine for cars is also in development, though currently progress has enabled HCCI on the lower RPM ranges of about 0 to 4,000rpm only. However, during normal non-spirited driving the rev rarely goes above 4,000rpm anyway.
A key problem is how to measure ignition timing accurately. This is not a problem in diesel self-ignition, as hot air is compressed and ignition starts when fuel is injected into the combustion chamber filled with the hot air. In a HCCI gasoline engine, the air-fuel mix is already in the combustion chamber before the piston starts compressing it. According to Lawrence Livermore Laboratory, some ways to ovecome this would be to recirculate exhaust gases into the fuel/air mix to quickly raise its temperature, or to add dimethyl ether to the fuel/air mixture to improve combustion.
Another idea would be to compress the air-fuel mixture to the point where it is just about to ignite, then injecting a second dosage of low octane fuel that combusts easily. That fuel would detonate, increasing temperature and detonating the rest of the air fuel mixture. The ignition timing could start from whenever the engine injects that second dosage of fuel.
Like most auto engines, HCCI engines inject a premixed charge of fuel and air into the cylinder. But combustion is not set off by a spark plug. Instead, the mixture is compressed until it autoignites, much like in a diesel at a much lower temperature. This virtually eliminates NOx emissions and lowers throttling losses, which could lead to a 30% boost in fuel economy. HCCI engines would also use a higher ratio of air to fuel, high compression ratios (on the order of 12:1), and burn a variety of fuels, including methane.
No fundo juntam tecnologia e o motor trabalha de modo similar a um Diesel trazendo as vantagens e desvantagens deste. Sendo a combustão da gasolina mais limpa poderá ser um grande avanço em termos de rendimento. Acaba por matar o epirito de um motor Otto devido à limitação de rotação.
Vai ser como os dieseis sem barulho de batedeira [:D]
Não estou tão certo disso. Como funciona por detonação e não por combustão deves ter o mesmo "melodioso" som.
Curiosamente, a detonação é aquilo que se quer evitar a qq custo num motor otto.
hummm... porreiro... vamos ficar com motores a gasolina a fazer o mm barulho dos diesel... o mesmo trabalhar.. a mesma limitação de rotações... supostamente os mesmo consumos e performances... mas.. com o combustivel mais caro... certo? what's the point?? Lol
Dizer que o caminho de evolução para os motores a gasolina é aproximar o seu funcionamento ao funcionamento dos motores a gasóleo deve ser para muitos um grande sapo para engolir[:)]
A verdade é que esta poderá ser mais uma daquelas maravilhas que fica muito bem em comunicados de imprensa, mas que nunca vêem a luz dos dias.
A limitação de rpm que alguém referiu como problema, não o será! Porque em teoria, corrijam-me se estiver enganado, um aumento de eficiência dinâmica provocará um aumento no binário... e como potência=binário x rotação[;)]
A lutar contra o progresso? [;)]
Eras tu quem vociferava no Restelo há 400 anos atrás?
Eu disse anteriormente, sobre outro propósito, mas digo agora novamente.
Não sou contra o desenvolvimento, mas não sou obrigado a gostar do mesmo.
Neste caso, para mim, mataria toda a filosofia do ciclo otto, a coisa que mais adoro no mundo automóvel.
Caso esta notícia fosse avante, muito morreria neste mundo precioso.
Segundo entendi, os regimes mudariam...
Se assim não for, menos mal então.
De afcto não me parece haver lógica para haver uma alteração significativa do limite máximo de regime, dado que o que condiciona os baixos regimes máximos dos diesel serem o próprio gasóleo, certo?
Nao sei onde foste buscar a ideia dos motores ficarem a fazer o mesmo barulho :confused:
O "point" é que no mundo em geral a gasolina e o diesel estao ao mesmo preço (portugal nao é exemplo pra ninguem), e os motores otto emitem menos poluentes que destroem a camada de ozono e com esta nova geracao emitiriam tambem menos co2 que a concorrencia diesel.
Ao mesmo tempo tambem permitem que em vez de gasolina se use outros tipos de combustivel alternativo como o metano.
O Diesel tem um custo de produção inferior, logo se estão ao mesmo preço ou são os impostos ou é alguma logica de mercado, mas o mais normal é ser mais barato.
Tens um custo de produção inferior não quer dizer que seja mais barato de comercializar, porque tiras litros de diesel de um barril de petroleo que de gasolina [;)]
Mas será que a limitação de rpm é uma realidade? Tipo, a partir das 4000rpm poderia começar a funcionar do modo convencional, decerto que se poderá preparar os injectores e motor dessa forma.
Assim seria perfeito, o melhor de dois mundos. Um "diesel" k n morre ás 4000 e pode continuar até ás 8000 por ex, como um otto normal.
Em conduçao diaria terias os beneficios de consumos baixos e binario, e quando querias puxar estava lá o motor pronto para tal.
Ou será que estou a ver mal?
A eficiência nunca será a mesma do diesel. A quantidade de energia contida num litro de gasolina é inferior à de um litro de gasóleo. Este é um facto determinado pela química.
Acredito, sim, que se possa melhorar em relação ao que temos hoje.
Não acho que o barulho seja um problema porque o que muda é o método de despoletar a ignição. Uma diferênça entre a gasolina e o gasóleo é que a gasolina "explode" (mais rápido) e o gasóleo "arde" (mais lento). Daí chamarem-se aos motores a gasolina motores de explosão e aos diesel motores de combustão.
o mesmo barulho dos diesel?
pelo que percebi, a gasolina acaba por se incendiar sozinha, nao por ignição! Continua a haver a combustão...Por isso o barulho do motor nao deve mudar.
As mesmas perfomances?
Referes-te ao binario?
Duvido que estes motores tenham tanto binario como os diesel. Nao vao ser tao pesados nem ter tanta taxa de compressao como os diesel, por isso o funcionamento deve-se manter igual...
"É que, mesmo sem os impostos (ISP e IVA), os preços dos combustíveis, à saída das refinarias, estão acima da média europeia. Assim, a gasolina de 95 "custa" 45,6 cêntimos por litro, o que é 2,4% mais caro do que a média da UE. O gasóleo, antes de impostos, custa 51,5 cêntimos, 1,7% acima da média europeia."
tirado de uma notícia de 28/6/06, penso que a diferença não se tenha alterado muito até hoje.
