A diferença é que o Sempron é um Athlon "capado" de alguma memoria e de alguma velocidade... É como os Celerons e os Pentiums..
Se for para um PC low budget um Sempron serve, se tiveres algumas pretensões de performance em multimédia e jogos, vai para o Athlon sem pensar duas vezes.. Aliás, por 5 euros, nem sei qual é a duvida..![]()
citação:Originalmente colocada por jmpub
http://www.asus.com/products4.aspx?l1=3&l2=101&l3=296&model=1138&modelmenu=1
Specification
CPU
Support AMD® Socket AM2 Athlon 64 X2 / Athlon 64 FX / Athlon 64/ Sempron
AMD Cool 'n' Quiet™ Technology
AMD64 architecture enables simultaneous 32-bit and 64-bit computing
AMD Live!™ Ready
Chipset
NVIDIA GeForce 6150 + nForce 430
Front Side Bus
2000 / 1600 MT/s
Memory
Dual channel memory architecture
4 x 240-pin DIMM, support max. 8GB DDR2 800/667/533 ECC and non-ECC,un-buffered memory
VGA
Integrated GeForce 6 GPU
High Definition Video Processing with max. resolutions to 1920 x 1440 (@ 75Hz)
Dual VGA output support: DVI-D and RGB
Note: DVI-D can not be converted to output RGB signal to CRT.
TV-out support: SDTV & HDTV (bundles HDTV/AV/S output module)
Note: RGB and TV-Out can not be used simultaneously.
Expansion Slots
1 x PCI Express x16
1 x PCI Express x1
2 x PCI
Storage/RAID
South bridge: NVIDIA nForce 430
*2 x UltraDMA 133/100/66/33
*4 x Serial ATA 3Gb/s with RAID 0, RAID 1, RAID 0+1, RAID 5 & JBOD
NVIDIA MediaShield™ RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
LAN
NVIDIA nForce® 430 built-in Gigabit MAC with external Marvell PHY
Audio
ADI AD1986A High Difinition Audio 5.1channel CODEC
Support Jack-Sensing and S/PDIF out interface
IEEE 1394
TI IEEE 1394a controller supports 2 x 1394a ports
USB
Up to 8 USB2.0/1.1 ports
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR, PXE, Chassis Intrusion
BIOS
4Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI 2.0
Overclocking Features
SFS (Stepless Frequency Selection) from 200MHz to 400MHz at 1MHz increment
ASUS O.C. Profile: overclocking configuration-sharing tool
Overclocking Protection:
ASUS C.P.R.(CPU Parameter Recall)
Special Features
ASUS Q-Fan 2
ASUS My Logo
ASUS CrashFreeBIOS2
ASUS EZ Flash 2
Note: CrashFree BIOS2 and EZ Flash 2 only support VGA/RGB output, but does not support VGA/DVI-D output.
Back Panel I/O Ports
1 x VGA/DVI-D out
1 x VGA/RGB out
4 x USB 2.0 ports
1 x IEEE 1394a port
1 x 5.1 channel Audio I/O
1 x RJ45
1 x PS/2 Mouse
1 x PS/2 Keyboard
1 x Parallel
Internal I/O Connectors
2 x USB 2.0 connector supports additional 4 USB 2.0 ports
1 x IEEE 1394a connector
1 x TV out connector
1 x Game/MIDI connector
1 x S/PDIF output connector
High Definition Front panel audio connector
4-pin CPU Fan / 2*Chassis Fan connectors
Chassis Intrusion connector
CD audio-in connector
24-pin ATX power connector
4-pin ATX 12V Power connector
2 x COM connectors
Support CD
Drivers
ASUS PC Probe II
ASUS LiveUpdate Utility
AMD Cool ' n' Quiet Utility
Anti-virus software (OEM version)
Accessories
2 x Serial ATA cables
1 x SATA power cable for two devices
1 x IDE cable
1 x UltraDMA 133/100/66 cable
1 x FDD cable
1 x IEEE 1394 cable
1 x I/O Shield
HDTV/AV/AS output module
User's manual
Form Factor
uATX Form Factor, 9.6" x 9.6" (24.5cm x 24.5cm)
interessa isto
Ou seja, penso que os que tens ai, dão perfeitamente..
São socket AM2
citação:Originalmente colocada por Bruno Grilo
Já agora junte-se uma memória RAM:
DDR400Mhz 1x 512 - 68,28€
ou
DDR 333Mhz 1x 512 333Mhz ECC 82,60€
ou
DDR SO-DIMM 1x 512 400Mhz 77,12€
ou
ou
memoria 1: normal
memoria 2: ECC? não precisas disso
memoria 3: isso é para portátil.
A performance provavelmente será quase a mesma... Mas as mainboards com chipset VIA nunca foram famosas pelos imensos bugs e instabilidade.. Já a nVidia tem uma re****ção de qualidade.
Aliás, muito do sucesso recente da AMD deve-se as nforce, porque antes disso as mainboards para AMD eram uma miseria autentica.
eu sou suspeito, pois sempre gostei mais da AMD e desde o primeiro PC (AMD 486DX4 100Mhz) sempre dei preferencia e fiquei satisfeito com a AMD.
e nesses dois iria na mesma para AMD
