Topico dos Crash-Tests ⚠️Euroncap- 10/10/2026
Volkswagen ID. Buzz Euroncap 2022
image.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.pngimage.png
In both the side barrier test and the more severe side pole impact, dummy readings indicated good protection of all critical body areas. However, in the pole test, the curtain airbag got trapped on the interior trim and did not fully deploy as intended, so a penalty was applied to the head score in both side impacts
Peugeot 408 2022 Euroncap
​The Peugeot 408 is very closely related to the 308 tested earlier in 2022. Some additional tests have been performed on the 408 but the rating is largely based on the results of the 308.
Global Ncap
Mahindra Scorpio N
https://static1.squarespace.com/sta...4556937/MahindraScorpio-N-2022-fact-sheet.pdf
Maruti Suzuki S-PRESSO Latin Ncap
https://static1.squarespace.com/static/5fb4ea8933ae6c208c3dac41/t/6396c3009d2b4f6eede75fb9/1670824707274/MarutiSuzukiS-Presso-2022-fact-sheet.pdf​
Suzuki Maruti Swift Latin ncap
https://static1.squarespace.com/stat...fact-sheet.pdf
https://static1.squarespace.com/static/5fb4ea8933ae6c208c3dac41/t/6396c346cc8beb3722085a7c/1670824776849/MarutiSuzukiIgnis-2022-fact-sheet.pdf
