(Traduzido por Google Translate)
Bit set with special bits, 71 parts:
- Color coded bits for common and special screw head profiles in the most important sizes
Including plastic box with window;
- 6x 25 mm Philips bits: 2x PH1, 2x PH2, 2x PH3, ring color: red;
- 6x 25 mm Pozidrive Bits: 2x PZ1, 2x PZ2, 2x PZ3, ring Color: light blue;
- 6x 25 mm slot bits: 2x SL 0.8 x 4.0 mm; 2x SL 1.0 x 5.0 mm; 2x SL 1.0 x 6.0 mm, ring color: orange;
- 9x 25 mm Torx (with hole) Bits: 1x T10H, 2 x T15H, 2x T20H, 2x T25H, 1x T27H, 1x T30H, ring Color: dark blue;
- 6x 25mm Hexagon Bits: 2x H4, 2x H5, 2x H6, ring color: pink;
- 3x 25 mm special bits (thumbscrew): 1x C1 - 1x C2 - 1x C3, ring Color: deep magenta;
- 4x 25 mm special bits (Torx Plus): 1x R4 - 1x R5 - 1x R6 - 1x R7, ring Color: purple;
- 4x 25 mm special bits (square): 1x S0 - 1x S1 - 1x S2, 1x S3, ring Color: light green;
- 4x 25 mm special bits (tensioner): 1x SP4 - 1x SP6 - 1x SP8 - 1x SP10, ring Color: green;
- 3x 25 mm special bits (Torq-set): 1x TS6 - 1x TS8 - 1x TS10, ring color: white;
- 4x 25mm special bits (Tri-Wing): 1x TW1 - 1x TW2 - 1x TW3 - 1x TW4, ring Color: Tangier Tango;
- 4x 25 mm special bits (screwdriver bits with external serration, for screws with internal serration): 1x M4 - 1x M5 - 1x M6, 1x M8 - ring Color: brown;
- 3x 75 mm Philips Bits: 1x PH1, 1x PH2, 1x PH3, ring Color: red;
- 2x 75 mm Pozidrive bits: 1x PZ1, 1x PZ2, ring Color: light blue;
- 2x 75 mm slot bits: 1x SL 0.8 x 4.0 mm; 1x SL 1.0 x 6.0 mm, ring color: orange;
- 2x 75 mm Torx bits: 1x T20, 1x T25, ring Color: yellow;
- 1x bit for Schraubhake (alloy steel, not chromed, not polished, no colored ring);
- 1x 60 mm - magnetic bit holder;
- 1x 65 mm - magnetic quick-change bit holder with one-hand operation.
