[FONT="]Through various weight-saving measures, the engineers from Molsheim have managed to reduce the weight of the Bolide to only 1,240 kilograms (2,734 pounds) or about as much as a typical European compact car. Doing the math, the track-only beast has an impressive weight-to-power ratio of 0.67 kg / hp. However, it’s worth pointing out that’s the dry weight of the car, meaning it’s heavier once you add all the necessary fluids.
[/FONT][FONT="]With so much power in a lightweight track-only hypercar, it’s no wonder the Bolide is an absolute rocket. 0 to 62 mph (100 km/h) takes a neck-twisting 2.17 seconds while 0-124 mph (0-200 km/h) is done in 4.36 seconds. Mind you, Bugatti hasn’t actually conducted these acceleration tests in real life as these are all simulated performance numbers. The same goes for the 0-186 mph (0-300 km/h) run in 7.37 seconds and 0-249 mph (0-400 km/h) in 12.08 seconds.[/FONT]
