Desligar Airbag Smart
Nop tas enganado ;) o airbag n pode disparar s en tiveres cinto de segurança, os cabos k tu ves a ir pro banco é pro pre tensor e não para "celulas" de pressao ou lá o que chamaste
tb pode ser pros bancos aquecidos, mas fora disso, só pre tensor
Ia-te dizer para pesquisares, mas duvido que conseguisses encontrar.
Many advanced air bag technologies are being developed to tailor air bag deployment to the severity of the crash, the size and posture of the vehicle occupant, belt usage and how close that person is to the air bag module. Many of these systems will use multi-stage inflators that deploy less forcefully in stages in moderate crashes than in very severe crashes. Occupant sensing devices let the air bag diagnostic unit know if someone is occupying a seat in front of an air bag, whether the person is an adult or a child, whether a seat belt or child restraint is being used and whether the person is forward in the seat and close to the air bag module. Based on this information and crash severity information, the air bag is deployed at either a high force level, a less forceful level or not at all.
Many new vehicles are also equipped with side air bags. While there are several types of side air bags, all are designed to reduce the risk of injury in moderate to severe side impact crashes. These air bags are generally located in the outboard edge of the seat back, in the door or in the roof rail above the door.
Algumas destas características já são usadas hoje em dia.
Mais...
Airbags involve the extremely rapid deployment of a large cushion. While airbags can protect a person under the right circumstances, they can also injure or kill. To protect occupants not wearing seat belts, US airbag designs trigger much more quickly than airbags designed in other countries. As seat belt use in the US climbed in the late 1980s and early 1990s, US auto manufactures were able to adjust their designs. Today all airbag control units recognize if a belt is used and set the trigger time accordingly.
poracaso tive agora a ver e ha "smart airbags" (é assim mm k se xamam) k calculam tudo e mais alguma coisa, mas continuo a dizer k o smart nao aciona o airbag se nao tiveres lá o cinto posto, o meu mecanico rebentou 1 e ele nunca leva cinto (mania dos mecanicos) e a 1ª coisa k disse foi, ainda bem k nao levei cinto senão o airbag disparava ;)
Airbag off
Airbag off
Apenas tiras 4 parafusos e desligas a ficha por traz do airbag do passageiro.
A luz fica acessa e o airbag desligado.
PS: Uma coisa importante, faz isso com a bateria desligada. Abraços.
Podes fazê-lo mas não te esqueças é que isso é ilegal e constitui uma alteração às características técnicas da viatura e que em caso de acidente com danos pessoais tenho a ideia de que a seguradora te pode vir a pedir contas.
Amigo, ilegal é tu andares com o Airbag de passageiro ligado e com uma cadeira de bébé.
E não estas a fazer nada que os outros carros não façam. Lembro que por exemplo um novo Mondeo, tem que ir a oficina para desligar o airbag do passageiro. Ou seja desligar a ficha.
Acrescento ainda que o novo Smart tem a opção ISOFIX que permite desligar o Airbag com qualquer cadeira convencional. Algo que falhava na anterior geração.
Falha essa, porque a Smart nunca pensou ter o sucesso que teve com a antiga geração. E por isso criou uma alternativa, um sistema para desactivar o airbag, com a estrutura da cadeira deles. E não para vender as cadeiras deles, como alguns dizem.
