Mahindra BE 6e 2025
strecht
Lembram-se da Mahindra?
Parece que está de volta à ribalta.
Mahindra BE 6e 2025
INGLO Electric Origin Architecture
*Introductory price; Price does not include charger & Installation cost; Two charger options of 7.3 kWh and 11.2 kWh will be made available on chargeable basis.
  • Certified Range of 682 km (MIDC P1+P2) for BE 6e and 656 km (MIDC P1 + P2) for XEV 9e with 79 kWh advanced LFP battery pack
  • Lifetime battery warranty for both 79 kWh and 59 kWh battery packs. Valid for first registered owners only and applicable only on private registration. In case of ownership change, warranty on high voltage battery will be 10 years or 200,000 km, whichever is earlier from the first ever date of delivery of the vehicle. Full Details will be available at time of booking.
  • 3-in-1 integrated powertrain delivering up to 210 kW power
  • Acceleration of 0-100 km/h in 6.7 s for BE 6e and 6.8 s for XEV 9e
  • Fast charging: 20-80% in under 20 min (with 175 kW fast charger)
  • i-Link front suspension, 5 link rear independent suspension with Intelligent semi-active dampers
  • Brake-by-wire technology with Integrated electronic booster (IEB)
  • High Power Steering with Variable Gear Ratio (VGR) that enables tight TCD of 10 m
https://www.mahindraelectricsuv.com/
Pois parece. Parece que o Cybertruck teve um caso de uma noite com o CHR mk2 e nasceu isto
Portanto, se um tipo quiser um carro para a vida (sendo que no caso dos EV, o maior receio é motor e baterias), tem aqui uma boa proposta.
"Lifetime battery warranty for both 79 kWh and 59 kWh battery packs. Valid for first registered owners only and applicable only on private registration​"
nada mal:
"warranty on high voltage battery will be 10 years or 200,000 km, whichever is earlier from the first ever date of delivery of the vehicle"
nada mal:
e com preços 25% abaixo dos Atto3
