O que coloquei custa dentro desses valores ?
Pois, infelizmente sim! Os Kenetic não são nada baratos....
Specifications:
Kinetic Direct Drive (SRH)
Caliber 5D44
- Case: Stainless Steel (SRH001/SRH003)
Stainless Steel + Black IP (SRH005)
- Band: Stainless Steel(SRH001/SRH003), Stainless Steel + Urethane(SRH005),
Three fold clasp with push button release
- Glass: Sapphire crystal with anti-reflective coating
- Water resistance: 10 Bar
- Retail Price: The recommended retail price in Europe will be approximately €950-990
Velatura continues a marine watch tradition
Since the creation in 1965 of its first diving watch, SEIKO has many times accepted the greatest challenge to the watchmaker's skill - the challenge of building watches that can withstand the demands of ocean life. In 1975, SEIKO made the first diver's watch in the world to have a titanium case and to be suited to saturation diving to 600m. Velatura continues a several decade tradition of watches built to take the strain of life on the high sea.
Kinetic Direct Drive. The perfect technology to take on energy of the ocean
Professional and recreational sailors alike require one thing above all else in their choice of watch: reliability. They have to be able to trust their watch to perform, year in and year out, without fear of it winding down or of battery drain. For the most demanding watch users on the high seas, Kinetic Direct Drive is the ultimate technology of trust. Wear it and it maintains perfect time. It is recharged by the wearer's motion, but Kinetic Direct Drive can also be wound by hand. When winding the crown, the wearer can see the precise amount of energy generated on the Direct Drive indicator. Leave it for a few days and you can wind it to see the power being transmitted to the watch in real time - the perfect re-assurance that the watch is both operational and adequately charged.
Kinetic Direct Drive is an expression of SEIKO's emotional technology. It is built to allow maximum interaction with the wearer. It takes its energy from its wearer and allows him or her to relate in real time to its functions. To wear Kinetic Direct Drive is to experience time in a human, visceral and emotionally satisfying way. Like Velatura itself, Kinetic Direct Drive is built for the oceans.
Features of Kinetic Direct Drive
SEIKO Kinetic Direct Drive is an embodiment of the SEIKO's 'emotional technology'. It offers new and valuable benefits to the ecological and convenience advantages of every SEIKO Kinetic watch.
Two winding functions
As in all existing Kinetic calibers, the wearer automatically generates the electrical energy by her/his wrist movement. With Kinetic Direct Drive, however, the wearer can also generate energy by winding the crown.
Two indicator functions
Kinetic Direct Drive shows not only the power held in reserve but also the level of power generation when the wearer hand-winds the crown. The wearer can see and feel, in real time, the direct transfer of power from his or her winding of the crown to the reserve.
Kinetic Direct Drive creates a direct interaction between the human being and the watch!
1) Real-time Power Indicator function
The more power you generate, the more the hand moves!
The Direct Drive hand starts moving when the winding starts. The hand directly indicates the amount of the power generated. If you wind the crown in short strokes or gently, the hand only moves a little. But if you wind it in long strokes or with sufficient speed, the hand makes a large move across the indicator dial. Its motion is just like the movement of the hand on a tachometer of a car when you accelerate.
As you wind the crown, the starting point of the move gradually goes up according to the amount of power generated in the winding sequence. In that way, the wearer who winds the watch can check, during the winding process, how much power has been generated up to that point. When the winding is halted, the hand also stops to show how much power is generated until them.
Direct Drive is a new function, unique to Kinetic Direct Drive, designed as an "emotional technology" to bring more enjoyment and a deeper emotional bond between the watch and its wearer.
In this picture's case, the hand shows that the power has been generated to the full scale in the Real-time Power Indicator function which can be translated to 6 hours of power.
Note: This doesn't refer to the power reserve duration but to the power generation level.
2) Power reserve indicator function
After the winding is complete, the hand pauses at the Real-time Power Indicator function for 4 seconds, then it goes back down to the zero position and moves up again to show the total amount of power reserve, which is now the sum of the original power reserve amount and the newly generated amount.
So in this picture's case, the original power reserve was 12 hours and now the newly generated 6 hours amount of power is added to make a total of 18 hours. The total power reserve in Kinetic Direct Drive is one month
This chart above shows the indication of generated power status when winding. The time scale is different from that of the power reserve indicating status. If you wind for 5 seconds, you generate power for 1 hour, 15 seconds gives 3 hours, and 30 seconds gives 6 hours.
The power reserve indicator: The first column shows the hand position within the 20 steps marked on the indicator. The second column shows the indication of the dial.
The chart below shows the indication of the power reserve. The first column shows the hand position within the 20 steps marked on the indicator. The second column shows the indication on the dial.
When it is fully charged, the hand points to "M." "M" means 1 month. "W" means 1 week, "D" means 1 day and "12" means 12hours. The bottom column is the estimated time required for winding by hand and automatic. If you wind for 2 minutes, power for 1 day is generated.
A qualidade paga-se... lá que é lindo é [br
] [br
] [br
