Uau, não estava à espera de algo tão bom [br]
Estou curioso para ver a versão de produção, só espero que não seja como a Renault nos tem habituado:
concepts bonitos -> carros de produção banais
Clio III e Laguna III não são propriamente originais. [Banais em relação aos concepts, queres tu dizer. []
Porque se um Laguna II, Megane II e afins têm linhas banais (não estou a dizer que são bonitos ou feios)...[]
Clio III e Laguna III não são propriamente originais. []
Exacto, era isso mesmo que queria dizer, mas estava a pensar em casos mais recentes, tipo Twingo []
Se bem me lembro, para o Laguna II e Megane II não houve concept a antecipar o modelo de produção![]()
bom demais para sair assim como carro de série, infelizmente![]()
"Megane, a double showcase for design and technology, is also a research tool for it’s maker’s next genereation of models.
Megane is a very large 4-seat saloon, luxurious and comfortable, and characterised by its external and internal mobility. Its four sliding sidedoors open wide - there are no centre pillars - to reveal a modular interior layout: the front seats can pivot, that of the driver though 60deg to easy entry, that of the passenger though 180deg so as to face those in rear. The back seats are fully reclining, and have legrests, while the rear section of the cabin "glasshouse" can move aft by 35cm to add extra cabin space. The boot is equipped with a sliding-platform arrangement to ease loading. All the doors and windows, as well as the seats, are electrically operated with the position of the driver"s seat electrically memorised. The doors can be selectively opened at a distance thanks to a infra-red emitter control which, when inserted into the dashboard, disconnects the anti-theft alarm system and operates the automatic adjustment of the driver’s seat and steering wheel. Megane is built on a ultra-modern mechanical foundation: all four wheels are driven and steered, the auto-adaptive suspension is electronically controlled and the gear-box offers two modes of operation, manual or automatic. The V6Turbo engine produces 250bhp which is enough, given a Cd of 0.21 or 0.22 (depending on the position of the rear cabin section) to permit a maximum speed of over 160mph."
acho que estes photoshops vão estar muito proximos da realidade, olhando para o concept, pois muitas coisas são semelhantes
