\QUIZ/- Adivinhem que carro é!!
specs:
General Characteristics :
[FONT=Verdana, Arial, Helvetica, sans-serif]ABS, EPS, Air Condition, Leather Interior, Fibre Composite Body [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Engine : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]Type : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Central Rear, Gasoline [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Capacity (cc) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]998 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Cylinders : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]3 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Bore / Stroke (mm) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]71 x 84 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Numbers of the Valves : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]12 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Maximum Power hp (kw) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]68 (50) to 6000 (turbocharged version - 100 hp) [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Maximum Torque Nm / trm : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]93 to 3600 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Ignition : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]EFI INJECT PORT [/FONT]
[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Transmission :[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Type : 5 speed, 2tronic, manuel autom. [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Chassis : [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Tubular [FONT=Verdana, Arial, Helvetica, sans-serif]Front suspension : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Double triangle [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Rear suspension : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Simple triangle [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Brakes : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Disc / Disc [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Tyres : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]Front : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]165 / 60 R15 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Rear : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]165 / 60 R15 [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Dimensions : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif]Wheel Base : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]2350 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Front / Rear (mm) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]1490 / 1415 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Lenght / Width / Height (mm) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]3500 / 1600 / 1310 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Luggage Volume (l) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]200 [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]Fuel Tank (l) : [/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]35 [/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]Weight :[/FONT]
[FONT=Verdana, Arial, Helvetica, sans-serif]500kg [/FONT]
[/FONT]
[/FONT]
[/FONT]
