RespectRequired
Banido
assim, qual vai ser a diferença do a3 para o a4? sedan.
vai ser tudo mto iguall...
What you see here may or may not be part of the rear end of the next-generation Audi A3. The image is quite blurred so details are sketchy at best. What can be seen distinctly though are the four Audi rings, some Q5-like design cues and LEDs on the tail lamp. Of course the A3 wording on the registration plate tells us what car it is.
The next A3 should hit European showroom floors in 2010 since the current model has been in the market for six years now. Body styles will include a three-door hatch, a five-door Sportback, a cabriolet and a rumoured sedan for the US market which will be sold as a 2012 model.
The engines speculated to be in the lineup include the recently announced 1.2 TSI making 78kW (106hp), the 1.4 TSI producing 104kW (141hp) as well as a 1.8 TSI with 127kW (173hp). There will also be turbo diesels just as in the current model which will be topped by a rumoured 152kW (207hp) 2.0-litre TDI.
Sitting atop the pile for the first time will be an RS 3 model which has been spied during testing exercises. That car should run the same 250kW (340hp) 2.5-litre turbo found in the new TT RS. Mated with all these engines will be choice between a 6-speed manual or a new 7-speed DSG double-clutch transmission.
Novo Audi A3 III Sedan já em 2010!!!
Imagem: autointernationaal.nl
"O actual A3 está disponível apenas nas versões hatchback e cabrio. Agora a Audi veio confirmar que está a preparar uma versão sedan para o novo A3.
Esta nova carroçaria será lançada no final de 2010 como modelo de 2011. Esta versão estará também disponível nos EUA.
Adicionalmente a esta versão do A3, a Audi já confirmou seguirem-se de imediato os lançamentos do novo A1 e Q3.
A família A3 incluirá também uma versão RS que já vimos em testes no famoso circuito de Nürburgring.
O design do novo A3 seguirá as linhas do recentemente apresentado A7 Sportback concept. Mantenham-se atentos a mais detalhes, pois será uma questão de tempo para começarmos a ver os primeiros protótipos do A3 sedan."
Fonte: Globalmotors
A Audi vai lançar, no decorrer deste mês, duas novas versões do A3, ambas equipadas com o mesmo bloco 1.6 TDI common-rail, mas com níveis de potência diferentes.
Para a versão de 90 cv, a marca anuncia um consumo médio de 4,5 litros de gasóleo por cada 100 km, com emissões de CO2 de 118 g/km. A versão de 105 cv beneficia de outros melhoramentos – sistema start/stop combinado com recuperação de energia cinética no alternador, relações de caixa diferentes, por exemplo – para conseguir valores ainda mais atraentes: 4,1 L/100 km de consumo médio e emissões de CO2 de 109 g/km.
O importador nacional ainda não definiu os preços, mas estima-se que estes 1.6 TDI possam ter valores de acesso a partir de 27 mil euros.
a começar nos 27 mil mas só tem 90cv
cá pra mim, agora devem começar a fazer melhor preço nos 1.9 tdi... será que se consegue um 1.9 TDIe por 26mil€isto com abates à mistura, deve-se conseguir bom preço...
ainda só aponto o silencio como defeito nos 1.9 tdi... de resto não o acho muito desactualizado.
Sim. Mas um é 1600cc e outro 1900cc e essa sim faz toda a diferença no preço!mas ha algo que bate mal, o de 90cvs vai gastar mais e mandar mais co2 que o de 105 cvs ou 110
__________a versão de 105 cv beneficia de outros melhoramentos – sistema start/stop combinado com recuperação de energia cinética no alternador, relações de caixa diferentes, por exemplo – para conseguir valores ainda mais atraentes: 4,1 l/100 km de consumo médio e emissões de co2 de 109 g/km
por isso mesmo, quem vai comprar o de 90cvs??
Um burro. É que a emitir menos CO2 o de 105cv provavelmente até vai ser mais barato.
Continuo é a achar que o 1.6 TDI têm pouca potência. 90 e 105cv são valores muito ultrapassados.
Tenho as minhas duvidas LH. Fui ontem á Audi ter com um amigo, e o Attraction fica perto dos 30K.
Mesmo com um abate pelo meio n deve ser facil, a não ser algum que eles tenham matriculado mas esteja para lá encalhado.
São ambos 1.6...Sim. Mas um é 1600cc e outro 1900cc e essa sim faz toda a diferença no preço!
