MadDragon
O R21 trouxe muitos avanços, como o Fuego! [kiss]
Que avanços trouxe o Fuego?
As motorizaçôes para quem esteja interessado
- 1.4 L (1397 cc) petrol SOHC 8-valve I4; 68 PS (50 kW; 67 hp); top speed: 165 km/h (103 mph) (Turkish development from C series block, called C2J, also available in Portugal and Yugoslavia)
- 1.4 L (1397 cc) petrol OHV 8-valve I4; 70 PS (51 kW; 69 hp); top speed: 168 km/h (104 mph)
- 1.6 L (1565 cc) petrol SOHC 8-valve I4; 73 PS (54 kW; 72 hp); top speed: 165 km/h (103 mph); 0–100 km/h: 12.0 s (Argentinian development from C-series block, called C2L, available in Argentina and Colombia)
- 1.7 L (1721 cc) petrol SOHC 8-valve I4 carb.; 76 PS (56 kW; 75 hp); top speed: 173 km/h (107 mph); 0–100 km/h: 12.0 s (Available in TL and TLE models)
- 1.7 L (1721 cc) petrol SOHC 8-valve I4 SPI; 75 PS (55 kW; 74 hp); top speed: 172 km/h (107 mph); 0–100 km/h: 12.5 s
- 1.7 L (1721 cc) petrol SOHC 8-valve I4 carb.; 90 PS (66 kW; 89 hp); top speed: 185 km/h (115 mph); 0–100 km/h: 10.7 s (Available in TS, RS, GTS and TSE models)
- 1.7 L (1721 cc) petrol SOHC 8-valve I4 carb.; 88 PS (65 kW; 87 hp); top speed: 181 km/h (112 mph)
- 1.7 L (1721 cc) petrol SOHC 8-valve I4 MPI; 95 PS (70 kW; 94 hp); top speed: 185 km/h (115 mph); 0–100 km/h: 10.7 s
- 1.9 L (1870 cc) diesel SOHC 8-valve I4; 65 PS (48 kW; 64 hp); top speed: 160 km/h (99 mph); 0–100 km/h: 16.0 s (available in SD and GSD models)
- 2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI; 135 PS (99 kW; 133 hp); top speed: 220 km/h (137 mph); 0–100 km/h: 10.9 s (Available in GTX and TXE models)
- 2.0 L (1995 cc) petrol SOHC 12-valve I4; 136 PS (100 kW; 134 hp); top speed: 230 km/h (143 mph) ; 0–100 km/h: 9.2 s (available in the TXi and TXi Quadra models)
- 2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 175 PS (129 kW; 173 hp); top speed: 227 km/h (141 mph); 0–100 km/h: 7.2 s (available in Turbo and Turbo Quadra models).
- 2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 175 PS (129 kW; 173 hp); top speed: 217 km/h (135 mph); 0–100 km/h: 8.6 s
- 2.1 L (2068 cc) diesel SOHC 8-valve I4; 67 PS (49 kW; 66 hp); top speed: 164 km/h (102 mph) ; 0–100 km/h: 15.6 s (available in TD and GTD models)
- 2.1 L (2068 cc) diesel SOHC 8-valve I4; 73 PS (54 kW; 72 hp); top speed: 170 km/h (106 mph) ; 0–100 km/h: 15.1 s
- 2.1 L (2068 cc) diesel SOHC 8-valve I4 turbo; 88 PS (65 kW; 87 hp); top speed: 177 km/h (110 mph) ; 0–100 km/h: 11.8 s
- 2.2 L (2165 cc) petrol SOHC 8-valve I4 MPI; 110 PS (81 kW; 108 hp); top speed: 192 km/h (119 mph) ; 0–100 km/h: 9.9 s
[*]1.4 L (1397 cc) petrol SOHC 8-valve I4; 68 PS (50 kW; 67 hp); top speed: 165 km/h (103 mph) (Turkish development from C series block, called C2J, also available in Portugal and Yugoslavia)
[*]1.7 L (1721 cc) petrol SOHC 8-valve I4 SPI; 75 PS (55 kW; 74 hp); top speed: 172 km/h (107 mph); 0–100 km/h: 12.5 s
[*]1.7 L (1721 cc) petrol SOHC 8-valve I4 carb.; 88 PS (65 kW; 87 hp); top speed: 181 km/h (112 mph)
[*]1.7 L (1721 cc) petrol SOHC 8-valve I4 MPI; 95 PS (70 kW; 94 hp); top speed: 185 km/h (115 mph); 0–100 km/h: 10.7 s
[*]2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI; 135 PS (99 kW; 133 hp); top speed: 220 km/h (137 mph); 0–100 km/h: 10.9 s (Available in GTX and TXE models)
[*]2.0 L (1995 cc) petrol SOHC 12-valve I4; 136 PS (100 kW; 134 hp); top speed: 230 km/h (143 mph) ; 0–100 km/h: 9.2 s (available in the TXi and TXi Quadra models)
[*]2.0 L (1995 cc) petrol SOHC 8-valve I4 MPI turbo; 175 PS (129 kW; 173 hp); top speed: 227 km/h (141 mph); 0–100 km/h: 7.2 s (available in Turbo and Turbo Quadra models).
[*]2.2 L (2165 cc) petrol SOHC 8-valve I4 MPI; 110 PS (81 kW; 108 hp); top speed: 192 km/h (119 mph) ; 0–100 km/h: 9.9 s
Estás completamente a leste no que toca ao programa Renault 21... As muitas milhas, quilómetros... []
Esta internet, pá !
Então não é que meteram um árvores de cames na cabeça num motor Clèon ??? []
A árvore de cames em qualquer variante do motor Clèon é lateral e é activada por corrente, que por sua vez actuam sobre balanceiros que fazem a abertura e fecho das válvulas à cabeça.
Este motor nunca foi catalizado, logo, nunca existiu.
Mais um motor que nunca existiu...
O 1.721 cm3 teve 90 e posteriormente 92 cv nas versões a carburador duplo corpo.
A injecção era monoponto...
Mais um que nunca existiu.
O 2.0 teve sempre 120 cv. Mais nada.
São 140 cv e posteriormente 137 cv na versão catalisada.
Ou 162 cv na versão com catalisador.
110 ou 120 cv.
O Fuego foi como o 4L, o 4L, era um veículo que revolucionou o seu mercado, e o Fuego trouxe as melhorias dele, do mercado dele. Não foram muitas, e no 21 foram mais, mas ele também teve alguns avanços, sim. Corrijam-me se tiver erros.
E muito provavelmente também foste buscar estas informações à Internet.
Ou a documentação da marca. Pois... []
Errado, pois o dono anterior também colocou peças do 21 Turbo, não apenas o motor do 19. Tais peças que alteram e muito a estabilidade do carro.
Mas de qualquer forma, o turbo no carro também faz alterações devido a estar no 21. Sistema de escape, suspenção, entre outros. Aniway, é um desportivo com outro turbo...
